WCS and WLC
seatraxlady
I need to change the name on about 200 recently installed access points. I have an Excel file with the MAC addresses and new naming convention. Is there a way to import this file into the WCS or WLC to make this task easier?
Mike
ericgarnel
Level 7
Level 7
Yes, but it is quite painful
I posted a script in the forum that will allow you to do this
Here is the link:
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Wireless%20-%20Mobility&topic=General&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cc17d78/1#selected_message
You will need to build a flat file that has an entry per ap with the syntax per line
config ap name
The script was written for linux, but may work in other OSs with perl and expect
It will take some experimenting to tweak your variables, but it should work.
The posted script is for pulling info off the controller without snmp
I am still waiting for Cisco to put an IOS-like CLI on the controllers to make scripting easier.
