WCS Campus question
don.click1
Level 5
Level 5
If we define a "campus", does that mean that WCS will use the size of the campus in calculations for RSI, Rogues, etc, or is just used as a "grouping" of buildings?
We created a campus in WCS when we first purchased the software, but are wondering now if we did this incorrectly.
Any info appritiated..
sschmidt
The campus is more of a container for buildings.  It can be used to see from the campus map view if there are issues with the underlying buildings.  You are also able to edit the location presence info for the campus for further detail regarding this campus.
http://www.cisco.com/en/US/docs/wireless/wcs/6.0/configuration/guide/6_0maps.html#wp1204112
