WCS Location Calibration...
jdodson
Community Member
I am having trouble performing "calibration". I created a model for the 10th floor, walked around collected my data points, calibrated the floor and applied model to the 10th floor map. That worked great. Next, I tried to do the same on the another floor (the floor layout is different). But when I get to the part to "add data points" and select the appropriate floor I get a pop up error:
Windows Internet Explorer
Error(s): You must correct the following error(s) before proceeding:
Error: Object "CalibrationModel#1734276" does not exist.
It does this to every remaining floor I try to calibrate. Any thoughts??
WLC 4.0.179.11
WCS 4.0.81.0
LS 2.1.39.0
bstremp
Level 7
Level 7
Can you send me the full output of this error message?
"Object "CalibrationModel#1734276" does not exist"
I meant the output lines above and below this error line. That would help me to understand the error better and provide solution accordingly.
