WCS maps adding AP problem
Vicki Cullis
Community Member
I'm new to WCS, so I'm sorry if this is a dumb question.  I'm trying to add our existing APs to the Floor Plan and when I get to the "Position access points on Floor Area" page, I can see my selected APs in the upper left hand corner.  I can select one, which highlights it blue, but it will not move when I try to drag it.
Any ideas why this might be?
Thank you,
Vicki
Scott Fella
Have you tried a different browser?
-Scott
5 Replies 5
Scott Fella
-Scott
Thank you!
I knew it was a stupid question!
Chrome didn't like it.
Thanks again!
No problem... so did another browser work fine?
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Yes, that was the problem.  It is fixed now.
Thanks again.
Chrome is the supported browser in the newer platforms.
-Scott
