WDS authentication problem: "EAP failure received in clear text"
gabor.varga
Hi!
A installed a WDS with ACS 3.3 trial in conjunction with RSA SecureID ACE Server authentication. I use (EAP-GTC PEAP).
I use HP laptop with Intel PRO/Wireless 2200BG adapter and Intel software.
When authenticating ACE server accepts my login ("passcode accepted" message in ACE log). Despite this success authentication fails in WDS and there is no entry among nor failed attepts nor Passed attempts in the ACS log.
It is impossible is not it?
In WDS AP's log: "dot11_auth_dot1x_send_client_fail: Authentication failed for ..." (MAC)
The client software (Intel PROSet/Wireless) reports "EAP failure received in clear text" in its event log.
What does it mean??
Does anybody understand this message show up??
Gabor
ebreniz
Level 6
Level 6
You may be running into a bug here. See, if CSCec02979 matches the problem you are facing.
