Web Auth 9800 Redirection Issue
Tinei
Level 2
Level 2
We have recently migrated to Cisco Catalyst 9800 and we having an issue with a captive portal/web authentication. in the old 5508 we point to the same portal with no issues. However, the portal doesn't work on the new WLC. We have a publicly signed certificate for the virtual IP address that is resolvable on the internet.
When a user connects to Wi-Fi they are redirected to the external web server where they enter details. However, when it redirects it resolves to the Virtual IP DNS entry and we get error as attached "Page isn't working right now" with an err_empty_response, when you refresh that page you get redirected to the cisco consent page also attached, then you will get redirected to the success URL. We want the return from the external web server to auto redirect as with the old portal.
I have run a test with a RADIUS captive portal that also redirects to an external web portal and I have no issues. However, this portal doesn't authenticate but just captures information.
The ACL where created automatically by the controller, I have captures of traces, packet captures and cannot seem to see why the return response from the external web portal fails to redirect.
9 Replies 9
Hi @Tinei
 Did you install the certificate to the WLC?
What did you mean by "The ACL where created automatically by the controller, "
 You must create the ACL on the wlc.
"However, when it redirects it resolves to the Virtual IP DNS entry and we get error as attached "Page isn't working right now" with an err_empty_response"
How does it worked before? Dont you have a DNS entry pointing to an external DNS?
Tinei
Level 2
Level 2
Yes the certificate is installed on the WLC
When we create a new web auth parameter map and add the portal IP and redirect URL the controller automatically creates the WA-SEC ACL attached in the text file
On the old controller we see the redirect from the external portal back to Virtual IP DNS Name and it redirects to the success page, but on the 9800 it stops and doesn't automate that process.
Mark Elsen
  - Have a checkup of your controller configuration with the CLI command : show tech wireless , feed tha output into : https://cway.cisco.com/wireless-config-analyzer/
   Captive port web redirection issues can be analyzed with : https://logadvisor.cisco.com/logadvisor/wireless/9800/9800CWA
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Tinei
Level 2
Level 2
I have ingested the wireless config analyser with no help, but will look at the second one
We have narrowed it down to the POST from the web server "buttonclick: =4" which seems not be getting posted correctly, instead of auto redirect it stops on page.
   - Check logs on the webserver too  , also for the 9800 controller , use a recent software version if applicable , preferably 17.9.3 or above ,
 M.
Tinei
Level 2
Level 2
I posted the output from a successful portal and the one that is failing. As you can note that the process is almost similar but the failed one gets stuck on HTTP GET and it never proceeds from there.
Success Portal
Applying of intercept ACL
023/07/31 06:08:46.900070 {wncd_x_R0-0}{1}: [webauth-acl] [17797]: (info): capwap_9000000c[98af.65a7.d2e9][        0.0.0.0]Applying IPv4 intercept ACL via SVM, name: WA-v4-int-107.178.250.42-33, priority
2023/07/31 06:08:46.900462 {wncd_x_R0-0}{1}: [epm-redirect] [17797]: (info): [0000.0000.0000:unknown] URL-Redirect-ACL = WA-v4-int-107.178.250.42
Layer 3 Authentication Initiation
2023/07/31 06:08:46.996802 {wncd_x_R0-0}{1}: [client-auth] [17797]: (note): MAC: 98af.65a7.d2e9  L3 Authentication initiated. LWA
2023/07/31 06:08:46.996914 {wncd_x_R0-0}{1}: [client-auth] [17797]: (info): MAC: 98af.65a7.d2e9  Client auth-interface state transition: S_AUTHIF_L2_WEBAUTH_DONE -> S_AUTHIF_WEBAUTH_PENDING
2023/07/31 06:08:47.118937 {wncd_x_R0-0}{1}: [client-iplearn] [17797]: (info): MAC: 98af.65a7.d2e9  Client IP learn method update successful. Method: DHCP IP: 10.180.210.84
2023/07/31 06:08:47.119278 {wncd_x_R0-0}{1}: [client-iplearn] [17797]: (info): MAC: 98af.65a7.d2e9  IP-learn state transition: S_IPLEARN_COMPLETE -> S_IPLEARN_COMPLETE
HTTP Request
2023/07/31 06:09:18.281669 {wncd_x_R0-0}{1}: [webauth-httpd] [17797]: (info): capwap_9000000c[98af.65a7.d2e9][  10.180.210.84]HTTP GET request
2023/07/31 06:09:18.281690 {wncd_x_R0-0}{1}: [webauth-httpd] [17797]: (info): capwap_9000000c[98af.65a7.d2e9][  10.180.210.84]Parse GET, src [10.180.210.84] dst [121.79.127.49] url [http://www.msftconnecttest.com/connecttest.txt]
2023/07/31 06:08:57.978207 {wncd_x_R0-0}{1}: [webauth-httpd] [17797]: (info): capwap_9000000c[98af.65a7.d2e9][  10.180.210.84]GET rcvd when in LOGIN state
Radius Phase
2023/07/31 06:09:46.083207 {wncd_x_R0-0}{1}: [radius] [17797]: (info): RADIUS: Send Access-Request to 35.189.58.100:24403 id 0/6, len 449
2023/07/31 06:09:46.249538 {wncd_x_R0-0}{1}: [radius] [17797]: (info): RADIUS: Received from id 24403/6 35.189.58.100:0, Access-Accept, len 57
2023/07/31 06:09:46.249628 {wncd_x_R0-0}{1}: [radius] [17797]: (info): Valid Response Packet, Free the identifier
Acknowledgement of success – removal of intercept ACL
2023/07/31 06:09:46.249855 {wncd_x_R0-0}{1}: [webauth-acl] [17797]: (info): capwap_9000000c[98af.65a7.d2e9][  10.180.210.84]Unapply IPv4 intecept ACL via SVM, name "WA-v4-int-107.178.250.42-33",
2023/07/31 06:09:46.250871 {wncd_x_R0-0}{1}: [webauth-acl] [17797]: (info): capwap_9000000c[98af.65a7.d2e9][  10.180.210.84]Unapply IPv6 intecept ACL via SVM, name "IP-Adm-V6-Int-ACL-global",
2023/07/31 06:09:46.251496 {wncd_x_R0-0}{1}: [auth-mgr] [17797]: (info): [98af.65a7.d2e9:capwap_9000000c] Authc success from WebAuth, Auth event success
2023/07/31 06:09:46.251549 {wncd_x_R0-0}{1}: [ewlc-infra-evq] [17797]: (note): Authentication Success. Resolved Policy bitmap:4 for client 98af.65a7.d2e9
Redirecting to the original URL
2023/07/31 06:09:46.253438 {wncd_x_R0-0}{1}: [webauth-page] [17797]: (info): capwap_9000000c[98af.65a7.d2e9][  10.180.210.84]Redirect to Initial URL [https://www.xxxxyyyy.com.au/]
2023/07/31 06:09:46.253746 {wncd_x_R0-0}{1}: [client-auth] [17797]: (note): MAC: 98af.65a7.d2e9  L3 Authentication Successful. ACL:[]
Failed Portal
2023/08/02 04:54:49.290925 {wncd_x_R0-1}{1}: [webauth-acl] [18028]: (info): capwap_9040000f[98af.65a7.d2e9][        0.0.0.0]Applying IPv4 intercept ACL via SVM, name: WA-v4-int-172.64.149.27-25, priority:
2023/08/02 04:54:49.291212 {wncd_x_R0-1}{1}: [epm-redirect] [18028]: (info): [0000.0000.0000:unknown] URL-Redirect-ACL = WA-v4-int-172.64.149.27
2023/08/02 04:54:49.375374 {wncd_x_R0-1}{1}: [client-auth] [18028]: (note): MAC: 98af.65a7.d2e9  L3 Authentication initiated. LWA
2023/08/02 04:54:49.375466 {wncd_x_R0-1}{1}: [client-auth] [18028]: (info): MAC: 98af.65a7.d2e9  Client auth-interface state transition: S_AUTHIF_L2_WEBAUTH_DONE -> S_AUTHIF_WEBAUTH_PENDING
2023/08/02 04:54:49.422632 {wncd_x_R0-1}{1}: [client-iplearn] [18028]: (info): MAC: 98af.65a7.d2e9  Client IP learn method update successful. Method: DHCP IP: 10.180.210.84
2023/08/02 04:54:49.422932 {wncd_x_R0-1}{1}: [client-iplearn] [18028]: (info): MAC: 98af.65a7.d2e9  IP-learn state transition: S_IPLEARN_COMPLETE -> S_IPLEARN_COMPLETE
HTTP Request
2023/08/02 04:54:50.087918 {wncd_x_R0-1}{1}: [webauth-httpd] [18028]: (info): capwap_9040000f[98af.65a7.d2e9][  10.180.210.84]HTTP GET request
2023/08/02 04:54:50.087939 {wncd_x_R0-1}{1}: [webauth-httpd] [18028]: (info): capwap_9040000f[98af.65a7.d2e9][  10.180.210.84]Parse GET, src [10.180.210.84] dst [121.79.127.34] url [http://www.msftconnecttest.com/connecttest.txt]
2023/08/02 04:54:50.642191 {wncd_x_R0-1}{1}: [webauth-httpd] [18028]: (info): capwap_9040000f[98af.65a7.d2e9][  10.180.210.84]GET rcvd when in LOGIN state
023/08/02 04:55:19.132139 {wncd_x_R0-1}{1}: [webauth-httpd] [18028]: (info): capwap_9040000f[98af.65a7.d2e9][  10.180.210.84]Parse GET, src [10.180.210.84] dst [172.217.24.35] url
Captain82
Frequent Visitor
Frequent Visitor
Tinei - What was the fix? Having the same issue over here..
jspilde
Level 2
Level 2
Was this issue resolved? I have a similar issue with web auth redirection. Thanks.
Make new post for this case it better
MHM
