Web Auth Parameter Map - 9800 WLC
gavin.garrad
Visitor
Under Configuration -> Security -> Web Auth, on the new 9800 WLC you have a option called Web Auth Parameter Map.
How many Web Auth Parameter Map can you have on the new 9800 WLC?
I can't seem to find a number on this online.
But would it be reasonable to think that it is the same amount as WLAN? Since this is a feature/option that used to be in the SSID itself.
Mark Elsen
 - The parameter may also be available in the show running-config command output.  If so  , then use command line to setup with command completion question ->? at the end of  an indented command (setting this parameter). Sometimes then the short/info-command-documentation may provide an answer to  your question.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
saravlak
if its beyond 10 -on gui or cli i'd configure test web-auth profile to check or call the TAC to verify.
