WEB AUTH problem on WISM
jain.nitin
Level 6
Level 6
HiGuys We are facing issue in authenticating guest user via web authentication on WiSM.We have WiSM with 270 APs. We have guest ssid with web-auth enabled.we are running 4.2.061 code. It was working fine till last week, now suddenly it keeps getting off. Users are not getting web-auth login page. We had to disable the web-auth & reenable it then it again starts working. I dont know wht to do in this case. didnt find any log..whts going on in background.
need help to resolve it.
NK
Scott Fella
If this keeps happening and you know what the fix is, then i would suggest opening a TAC case. I have clients running 4.2.61 and 4.2.99 with no issues with web-auth.
-Scott
I had the same basic issue and after reseaching found caveat CSCsk54969 which is a pretty close match. This caveat has been fixed in release 4.2.130. I have just upgraded to this release over the week end so to soon to tell yet.... fingers crossed...
