WEB authenticaation
aalsayed
Community Member
we ahve wism wiht this version 4.0.179.11 and wcs
after i configured the web authentication the client is redirected to the url witout web login ,, even i didnt apply any url configuratinm nin the url redirect
my quesition haw i can get the web login
Khathorn
Community Member
You want to make sure that you go to WLANs page, select the WLAN SSID and then clik on Edit.
I believe Layer 3 Security should have the Web Policy checkbox activated AND the Passthrough radio button (it will appear once the checkbox is activated).
thnx for update
actully i have done this before ,, i ahve checked the web policy and i have checked authentication as well as ,, not passthrogh ,,
even it didnt work(web login page) by both authentication and passthrough..
please any feedback
