Web Authentication 1.1.1.1/login Redirect Issue Certificate ERROR
garyleggat
Creating a OpenSSL certificate 3rd Party request on release 8.2   . Can I be done through CLI of controller or do you still have to use openssl-0.9.8k_WIN32.
Scott Fella
You can do both but on the WLC you need to be on a later code. Using OpenSSL seems to be the easiest way from my experience.
Here is a link, as it should help.
https://support.quovadisglobal.com/kb/a475/how-to-generate-a-csr-on-a-cisco-wlc.aspx
-Scott
Here is another link which references the same but from Cisco
https://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/109597-csr-chained-certificates-wlc-00.html#anc9
-Scott
