Web authentication and MAB.
Yong Peng
Dear Experts,
Greeting.
I have a 2500 controller and a couple of APs, they are offering a guest WLAN with web authentication (local username/password on the controller).
A customer has a special endpoint, it wants to access the guest WLAN, but it doesn't have a  browser.
I am wondering if it is possible to create a MAB policy for that special endpoint? So, web authentication and MAB coexist on the SSID.
Does anyone have such experience?
Thanks in advance.
Philip91
Level 3
Level 3
Hello Peng,
yes it´s possible:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-0MR1/configuration/guide/wlc_cg70MR1/cg_wlan.html#pgfId-1460224
The feature is called "Configuring a Fallback Policy with MAC Filtering and Web Authentication"
Hope that helps...
Kind regards
Philip
--> Pls rate useful responses <--
Hi Philip,
Thanks a lot for your help.
I think it will work.
I will take a try later.
