Web Authentication Certificate
Dennis Kline
Level 3
Level 3
Running a 5508 with 8.5.151.0... the locally generated Web Authenticate Certificate is about to expire.
A number of years ago, I had to re-generate that same certificate on another system.  If I recall correctly, it was simply a matter of hitting the "regenerate" tab, applying, and then re-booting the WLC.
Is that about it?  Any "gotchas" that I should know about ?
[email protected]...(It takes an Act of God to fade a wireless path, but any fool with a backhoe can cut fiber)
Sandeep Choudhary
yes that enough if you just want to use the Cisco WLC inbuilt webauth cert.
Dont forget to rate helpful posts
Sandeep Choudhary
