Web Authentication Controller
keynet
Level 2
Level 2
Hello
I configured a guest-wlan with web-authentication. Now, I want from the user to confirm a security-policy after the login. Only if the user accepted this policy, it will get access to the internet.
How is the configuration for a such procedure?
Pascal
Richard Atkin
Level 10
Level 10
Two ways of achieving this. Firstly, you could implement NAC, and force your client to download an app from a web-page. If they install the app and pass the scans, they get access. If they don't install the app, or they fail the scans, they get dropped in to a private (quarantine) VLAN where they can do no harm.
Secondly, you could just present them with an Acceptable Use Policy that they have to accept as part of the authentication process.
Both options will require you to upload a custom web page to the WLC, which isn't too tricky.
Richard.
