Web GUI not accessible once an AP boots up
Cormac Champion
I don't know what is going on, but once any Lightweight AP connected to the 2504 controller boots up, the GUI is no longer accessible from a PC on the same subnet as the Management Interface.  It's still pingable.  I've no Access Lists in place
The SSID's are working at this point
6 Replies 6
Rasika Nayanajith
Pls provide us "show sysinfo" & "show interface detailed management" output from your WLC
Rasika
Product Version.................................. 8.2.100.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... TEST_SYSTEM
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 10.10.5.253
IPv6 Address..................................... ::
Last Reset....................................... Power on reset
System Up Time................................... 0 days 0 hrs 4 mins 4 secs
System Timezone Location......................... (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
--More-- or (q)uit
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... ES - Spain
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +20 C
External Temperature............................. +23 C
Fan Status....................................... 3800 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 3
Number of Active Clients......................... 0
Burned-in MAC Address............................ CC:D8:C1:41:1A:20
Maximum number of APs supported.................. 75
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1/SHA2
(Cisco Controller) >show interface detailed management
Interface Name................................... management
MAC Address...................................... cc:d8:c1:41:1a:20
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 10.10.5.254
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
Link Local IPv6 Address.......................... fe80::ced8:c1ff:fe41:1a20/64
STATE ........................................... REACHABLE
Primary IPv6 Address............................. ::/128
STATE ........................................... NONE
Primary IPv6 Gateway............................. ::
Primary IPv6 Gateway Mac Address................. 00:00:00:00:00:00
STATE ........................................... INCOMPLETE
VLAN............................................. untagged
Quarantine-vlan.................................. 0
Active Physical Port............................. 1
Primary Physical Port............................ 1
Backup Physical Port............................. Unconfigured
DHCP Proxy Mode.................................. Global
Primary DHCP Server.............................. 10.10.5.254
--More-- or (q)uit
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
DHCP Option 82 bridge mode insertion............. Disabled
IPv4 ACL......................................... Unconfigured
IPv6 ACL......................................... Unconfigured
mDNS Profile Name................................ Unconfigured
AP Manager....................................... Yes
Guest Interface.................................. No
L2 Multicast..................................... Enabled
I believe you hitting below issue. Enable LAG on your WLC & test this again.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn82.html
Guidelines and Limitations
  • After upgrading to Release 8.2, the Cisco WLC might lose all IPv4 connectivity. The Cisco WLC can no longer service incoming SSH/Web sessions and is unable to ping other IPv4 stations. However, the default router is able to ping the Cisco WLC’s management interface.
Every 10 seconds, a message similar to the following is sent to the msglog:
*dtlArpTask: Jan 06 23:50:37.312: %OSAPI-4-GW_ADD_FAILED: osapi_net.c:1032 Unable to add the gateway 192.168.145.1. System command returned failure. Errorcode:256
This occurs in the following conditions:
a. LAG is not configured.
b. The management interface is untagged and is mapped to one physical port.
c. When an untagged dynamic interface is added and mapped to port 2, the default route for the management interface is lost.
The workaround is to configure all interfaces with VLANs.
You can track this issue via CSCux75436.
Rasika
*** Pls rate all useful responses ***
Aaaarrrgggghhh
I have changed the Management Interface to Vlan 1 but when I do, I can no longer ping it from my Laptop, which is directly connected to port 1.  Have I mis-understood as to what is required to be done ?  Does Management need to be in a vlan other than Vlan 1 ?
I've changed the other interfaces onto another port too so the Management interface is on it's own port - but still not pingable
You need to configure LAG, see below
http://www.cisco.com/c/en/us/support/docs/wireless/2500-series-wireless-controllers/113034-2500-deploy-guide-00.html#anc24
Rasika
Got it sorted with Management in Vlan 0 on Port 1 and all other Interfaces with whatever Vlans, on Port 2
