Web GUI Timeout
rochoa8aeg
Level 3
Level 3
The web GUI timeout on my AP seems to be too short, if I login and sit idle for about 60 seconds when I select a different menu item I need to type in my credentials again. At that point I notice that on the login menu it says to login for priv access level 1. How can I increase the login timeout so I dont need to keep typing in my credentials. I've already typed in the command no exec timeout but that only seems to help when im using the command line.
13 Replies 13
Scott Fella
Edited... See other post:)
Scott Fella
Sent from my iPhone
-Scott
Scott Fella
Read your post wrong. You should be able to set the timeout from the management http/https section.
ip http timeout-policy
-Scott
Scott Fella
The app is not showing the correct CLI command
ip http timeout-policy idle
Scott Fella
Sent from my iPhone
-Scott
Scott Fella
Here is a link to a previous post
https://supportforums.cisco.com/thread/2109694
Scott Fella
Sent from my iPhone
-Scott
Sorry, I'm actually referring to an autonomous AP not a WLC.
I posted the autonomous commands also.
Scott Fella
Sent from my iPhone
-Scott
ip http timeout-policy idle <1-600 sec> life <1-86400>
For your SSH timeouts, you would want to modify the following under your vty line configuration:
exec-timeout
-Scott
Yes I did see that. What does the 'requests' mean because it requires me to type it in?
AP2(config)#ip http timeout-policy idle 600 life 6000
% Incomplete command.
AEGL-NASH-AP2(config)#ip http timeout-policy idle 600 life 6000 requests ?
  <1-86400>  Maximum number of requests allowed on a http server connection
How many connections do you want to allow a one time.
Scott Fella
Sent from my iPhone
-Scott
Is this VTY sessions allowed? I would think the same as the sessions limit 15, no?
You can... Depends on how many users might need access. Some
Like to limit it to 5 or less.
Scott Fella
Sent from my iPhone
-Scott
Great. So this is my command:
AEGL-NASH-AP2(config)#ip http timeout-policy idle 600 life 6000 requests 5
So I'm basically saying here that there is a policy on my AP that when I'm using the GUI and it's idle it will only remain idle for 600 seconds or 10 minutes, and only allow 5 simultaneous users at a time. Right?
Correct
Scott Fella
Sent from my iPhone
-Scott
