Web interface not work
remosa2010
Community Member
Good morning, i've purchased an AP LAP 1131AG, i need to access in web interface but this not work.
i've configured  static ip means console port, i ping that ip , but when i try to access in web interface this not work.
this is my startup:
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
Loading "flash:/c1130-rcvk9w8-mx/c1130-rcvk9w8-mx"...###########################
File "flash:/c1130-rcvk9w8-mx/c1130-rcvk9w8-mx" uncompressed and installed, entr
y point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1130 Software (C1130-RCVK9W8-M), Version 12.3(11)JX1, RELEA
SE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 17-Jul-06 11:38 by alnguyen
Image text-base: 0x00003000, data-base: 0x0035E440
Initializing flashfs...
flashfs[1]: 4 files, 2 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 1870848
flashfs[1]: Bytes available: 14128128
flashfs[1]: flashfs fsck took 4 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
cisco AIR-LAP1131AG-E-K9   (PowerPCElvis) processor (revision B0) with 24566K/81
92K bytes of memory.
Processor board ID FCZ1407Q1SD
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 3.0.51.0
1 FastEthernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 88:43:E1:AA:1A:E4
Part Number                          : 73-8962-14
PCA Assembly Number                  : 800-24818-13
PCA Revision Number                  : A0
PCB Serial Number                    : FOC140453YY
Top Assembly Part Number             : 800-29144-03
Top Assembly Serial Number           : FCZ1407Q1SD
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1131AG-E-K9
Press RETURN to get started!
*Mar  1 00:00:06.307: %CDP_PD-4-POWER_OK: Full power - AC_ADAPTOR inline power s
ource
*Mar  1 00:00:06.313: %SYS-5-RESTART: System restarted --
SE SOFTWARE (fc1)
*Mar  1 00:00:07.267: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to
up
*Mar  1 00:00:08.267: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0, changed state to up
dancampb
Level 11
Level 11
That AP is running a lightweigh image and doesn't have a web interface.  Are you planning on using this AP with a controller or as an autonomous AP?  If you want to use it as an autonomous AP you need to convert it:
http://www.cisco.com/en/US/docs/wireless/controller/6.0/configuration/guide/c60lwap.html#wp1105215
I need autonomous AP, for convert Ap i need the access point image file.
I can't download it from download area
You can use any of the autonomous IOS AP images to convert the AP.
where can i find autonomous IOS AP images ?
