Webauth Bundle for 9800
ittechk4u1
Level 2
Level 2
Hello Experts,
I am not good with HTML & CSS.
could anyone provide me the custom webauth bundle for 9800 WLC.
Thank in advance.
2 Accepted Solutions
Sandeep Choudhary
First of all you can download the Webauth bundle from cisco portal, here is the link:
https://software.cisco.com/download/home/286316412/type/282791507/release/16.10.1
Second, check this technote related to custom Webauth.......use this and modify as per your requirement
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/216121-custom-web-authentication-on-catalyst-98.html
Dont forget to rate helpful posts
Here I am attaching all the files.... you need to customize or ask someone to do it as per your requirement.
Dont forget to arte helpful posts
6 Replies 6
Sandeep Choudhary
Could yo please provide me all the required files with customized (login.html, .CSS, logout.html, Sucess.html) so that I can change them little bit and convert in .tar format and upload to WLC.
Thanks @Sandeep Choudhary
Its the default webauth bundle. Do you have customized version ?
Sorry, I don't have customized Webauth. You can use from this post:
Thank for your help.
