weird 1130 issue
js88888888
Level 4
Level 4
Somehow the enable pw got messed up in one particular AP and now I can't get back into it.
Its running LAP IOS but is not associated to any controller.
I've attempted to press/release the MODE button until it turned both amber and red but it still won't fully default its configuration to factory settings.
There is no longer a static IP (I can get in unpriveleged) but it keeps the name and whatever enable pw it has among a few other things.
Am I going to have to do the direct connect TFTP IOS loadup option?
Scott Fella
Try this:
First, check the flash:
lap_1131#dir
Directory of flash:/
2 -rwx 279 May 09 2008 11:52:20 +00:00 env_vars
4 -rwx 6168 May 09 2008 11:52:20 +00:00 private-multiple-fs
6 drwx 256 May 09 2008 11:49:05 +00:00 c1130-k9w8-mx.124-3g.JA2
5 drwx 128 Mar 01 2002 00:03:43 +00:00 c1130-rcvk9w8-mx
15998976 bytes total (10716672 bytes free)
Then delete the LWAPP image:
lap_1131#delete /r /f flash:/c11310-k9w8-mx.124-3g.JA2
Not the one the has rcv in it!!!!!!
Thirdly reload the AP:
lap_1131#reload
Then issue a clear lwapp private-config
You'll end up with a clear AP.
-Scott
Thanks! I saw your post on this solution earlier, or maybe someone else's. Easy fix.
