12-29-2023 07:34 AM
Hi I Wil migrate the old APs 1232 by C9115 But during the Time transition I need To have WPA2 ssid eand WEP SSID on my EWC
I tried this , the WPA works fine but not WEP
Could you help me to activate a WEP SSID on the EWC
Tnanks
12-29-2023 07:45 AM
M.
12-29-2023 08:15 AM
Ok I readed this document but I Hope to find a solution
Below the configuration of my wlan
dot11ax target-waketime
dot11ax twt-broadcast-support
no security ft adaptive
no security wpa
no security wpa wpa2
no security wpa wpa2 ciphers aes
no security wpa akm dot1x
security static-wep-key encryption 40 ascii 0 xxxxx1
no shutdown
