02-23-2005 07:37 PM - edited 07-04-2021 10:29 AM
Using an 1100 running c1100-k9w7-mx.122-13.JA4.
Without WEP(128 bit) it works fine. I am using it for 7920 wireless phones and laptop access. As soon as WEP is enabled both the phone and laptop associate to the AP, but cannot route, cannot ping the AP or anything associated with it. On the wired network portion access to the AP is still there, but not to anything associated to it. Any Ideas?
02-28-2005 07:43 AM
Bump. Anyone have an idea on this one?
02-28-2005 09:26 AM
Havent encountered this issue yet. I have not got a chance to upgrade my AP 1100 to the latest yet, but 12.2.8 JA doesnt seem to have this problem. I would recommend you to try 12.3.2.JA2 and see if that helps
02-28-2005 12:34 PM
I loaded the latest version, going to test it when I get home and see if that corrects it. On another note, I saw something in my perusing of the countless numbers of documents on Cisco regarding the 1100 series about the order of the wep keys. The AP is set to key 2, does the phone and laptop need to use key 2 as well? If so wouldnt that cause an authentication issue? All the keys are the same.
