05-31-2013 06:05 AM - edited 07-04-2021 12:09 AM
I've got a wes610n Cisco/Linksys that I'm trying to connect to our wireless network to use as a network adapter. I was able to get it connected to the network with a static address to the wireless, but I cannot ping it. On the wlc it shows connected and in RUN status but will not ping in or out. The ssid is using just a WPA2/PSK password and it matches on both the wlc and the wireless client. I've run a debug client (mac) on the wlc and it keeps giving this message:
*apfMsConnTask_2: May 31 07:59:49.529: Stats update: Non Zero value
I've looked throughout Cisco documentation and cannot find it. I'm running 7.4.100.0 on the wlc with a 3602i AP.
Solved! Go to Solution.
05-31-2013 07:02 AM
Wi-Fi Protected Access (WPA/WPA2)............. Enabled
WPA (SSN IE)............................... Enabled
TKIP Cipher............................. Enabled
AES Cipher.............................. Disabled
WPA2 (RSN IE).............................. Enabled <-- Disable this
TKIP Cipher............................. Disabled
AES Cipher.............................. Enabled <-- Disable this
Scott
Help out other by using the rating system and marking answered questions as "Answered"
05-31-2013 06:08 AM
Post your show wlan
Scott
05-31-2013 06:10 AM
Here is something I have found
http://www.cisco.com/en/US/products/ps6366/products_qanda_item09186a00808b4c61.shtml
A. No, the WLC supports only Cisco WGB products. Linksys WGBs are not supported. Although the Cisco Wireless Unified Solution does not support the Linksys WET54G and WET11B Ethernet Bridges, you can use these devices in a Wireless Unified Solution configuration if you use these guidelines:
- Connect only one device to the WET54G or WET11B.
- Enable the MAC cloning feature on the WET54G or WET11B to clone the connected device.
- Install the newest drivers and firmware on devices connected to the WET54G or WET11B. This guideline is especially important for JetDirect Printers because earlier firmware versions cause problems with DHCP.
Note: Other third-party bridges are not supported. The steps mentioned can also be tried for other third-party bridges.
Scott
05-31-2013 06:12 AM
I do have a Buffalo WLI-TX4-AG300N on my wireless, but it has to be rebooted once a week or so. I had to enable passive client on the WLAN advanced tab.
Scott
05-31-2013 06:11 AM
(Cisco Controller) >show wlan 2
WLAN Identifier.................................. 2
Profile Name..................................... HP-Guest
Network Name (SSID)..............................HP-Guest
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
Client Profiling Status ....................... Disabled
DHCP ......................................... Disabled
HTTP ......................................... Disabled
Radius-NAC State............................... Disabled
SNMP-NAC State................................. Disabled
Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 1
Exclusionlist.................................... Disabled
Session Timeout.................................. 86400 seconds
User Idle Timeout................................ 300 seconds
--More-- or (q)uit
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... fmc01a2504
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ hpidc
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
mDNS Status...................................... Enabled
mDNS Profile Name................................ default-mdns-profile
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream Downstream
Average Data Rate................................ 0 0
Average Realtime Data Rate....................... 0 0
Burst Data Rate.................................. 0 0
Burst Realtime Data Rate......................... 0 0
Per-Client Rate Limits........................... Upstream Downstream
--More-- or (q)uit
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Disabled
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
Authentication................................ Disabled
Accounting.................................... Disabled
Dynamic Interface............................. Disabled
Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Security
--More-- or (q)uit
802.11 Authentication:........................ Open System
FT Support.................................... Disabled
Static WEP Keys............................... Disabled
802.1X........................................ Disabled
Auth Key Management
802.1x.................................. Disabled
PSK..................................... Enabled
CCKM.................................... Disabled
FT-1X(802.11r).......................... Disabled
FT-PSK(802.11r)......................... Disabled
PMF-1X(802.11w)......................... Disabled
PMF-PSK(802.11w)........................ Disabled
FT Reassociation Timeout................... 20
FT Over-The-DS mode........................ Enabled
GTK Randomization.......................... Disabled
--More-- or (q)uit
SKC Cache Support.......................... Disabled
CCKM TSF Tolerance......................... 1000
WAPI.......................................... Disabled
Wi-Fi Direct policy configured................ Disabled
EAP-Passthrough............................... Disabled
CKIP ......................................... Disabled
Web Based Authentication...................... Disabled
Web-Passthrough............................... Disabled
Conditional Web Redirect...................... Disabled
Splash-Page Web Redirect...................... Disabled
Auto Anchor................................... Disabled
FlexConnect Local Switching................... Disabled
flexconnect Central Dhcp Flag................. Disabled
flexconnect nat-pat Flag...................... Disabled
flexconnect Dns Override Flag................. Disabled
FlexConnect Vlan based Central Switching ..... Disabled
FlexConnect Local Authentication.............. Disabled
FlexConnect Learn IP Address.................. Enabled
Client MFP.................................... Optional
PMF........................................... Disabled
PMF Association Comeback Time................. 1
PMF SA Query RetryTimeout..................... 200
Tkip MIC Countermeasure Hold-down Timer....... 60
--More-- or (q)uit
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flow Monitor Name................................ None
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID IP Address Status
802.11u........................................ Disabled
MSAP Services.................................. Disabled
05-31-2013 06:14 AM
This is wrong
You need to either use WPA/TKIP or WPA2/AES.... try WPA/TKIP first then try WPA2/AES.
Also enable passive client
Scott
05-31-2013 06:24 AM
I enabled the passive client and changed the cipher for WPA and WPA2 but still no bueno
05-31-2013 07:02 AM
Scott
05-31-2013 07:29 AM
That worked....Thanks for all your help
05-31-2013 07:34 AM
So now what you can do is use WPA2/AES, since you know that WPA/TKIP works
WPA (SSN IE)...............................Disabled
TKIP Cipher.............................Disabled
Scott
