what am i doing wrong ? wireless config issue
alzzstar84
Community Member
im at a loss, i have setup a 1131 with multiple ssid's, they show up, but neither one will connect.  i need 2 ssid's, one open and one protected. this is the config i have so far:
version 12.3
no service pad
service password-encryption
hostname ap
enable secret 5 $1$lrBX$8Z39Oh0JQPGmxWdHEvXo20
ip subnet-zero
ip domain name s02710.US.wal-mart.com
ip name-server 10.223.80.132
no aaa new-model
dot11 ssid Ncc Guest
   vlan 30
   max-associations 50
   mbssid guest-mode
dot11 ssid Ncc Staff
   vlan 20
   max-associations 50
   mbssid guest-mode
dot11 network-map
power inline negotiation prestandard source
username Cisco password 7 14341B180F0B
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 ssid Ncc Guest
 ssid Ncc Staff
 mbssid
 speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
 station-role root
 bridge-group 1
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
 bridge-group 1 spanning-disabled
interface Dot11Radio0.20
 encapsulation dot1Q 20
 no ip route-cache
 bridge-group 20
 bridge-group 20 subscriber-loop-control
 bridge-group 20 block-unknown-source
 no bridge-group 20 source-learning
 no bridge-group 20 unicast-flooding
 bridge-group 20 spanning-disabled
interface Dot11Radio0.30
 encapsulation dot1Q 30
 no ip route-cache
 bridge-group 30
 bridge-group 30 subscriber-loop-control
 bridge-group 30 block-unknown-source
 no bridge-group 30 source-learning
 no bridge-group 30 unicast-flooding
 bridge-group 30 spanning-disabled
interface Dot11Radio1
 no ip address
 no ip route-cache
 shutdown
 ssid Ncc Guest
 ssid Ncc Staff
 mbssid
 speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
 station-role root
 bridge-group 1
interface Dot11Radio1.20
 no ip route-cache
 bridge-group 20
interface Dot11Radio1.30
 no ip route-cache
 bridge-group 30
interface FastEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 bridge-group 1
 hold-queue 160 in
interface FastEthernet0.20
 no ip route-cache
 bridge-group 20
interface FastEthernet0.30
 no ip route-cache
 bridge-group 30
interface BVI1
 ip address 192.168.1.175 255.255.255.0
 no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
line con 0
line vty 0 4
 login local
end
But, its not working.... what have I done wrong?
Its currently hooked through a simple linksys router. I can ping through console and reach out, so that is ok.
satish Chowdary
Aceess point ethernet port connected to which VLAN interface ??? that should be connected to managemant VLAN interface only.
how can you get the IP address ?? through VALN interface or external DHCP server.
kcnajaf
Level 11
Level 11
Hi Brend,
You have mentioned that you have one ssid open and other other as protected..But i'm not able to see relavant config for the same on AP.
Assuming you are using open authetication of Ncc Guest SSID, try applying below config and see if it is connecting?
authentication open
For other SSID you have not mentioned what protection (WPA/WPA2 etc...) you are using and hence not able to guide with the configuration.
Najaf
