What interface does the WLC talk from for Radius Auth
moorera
I have the situation where I need to talk to multiple different Radius servers depending on the WLAN.  Some of the WLANs are not able to route traffic over my entire network, and within these secure areas the Radius server for that area sit.  Is there away that I can instruct the WLC to use its virtual interface to make the Radius Auth instead of using the WLCs Management interface?
Randy Moore
6 Replies 6
Scott Fella
The communication from the WLC and Radius uses the management ip of the wlc. Your defined AAA client in radius has to use the management ip... The VIP will not work.
Why wouldn't you have routing between the management and the subnet(s) your radius server is on?
-Scott
Hi Scott,
Thanks for the reply.  We have the setup we have as two companies in the middle of a JV and different support models/needs in a new office. I don't want to have two WLCs and APs throughout the building so we are doing 1 with different needs.... Due to the different support arrangements a PC from one legacy company is not allowed on the network of the others... Lot's of fun.
Thanks again for the help.
Randy
Scott Fella
It doesn't matter if the user WLAN does not route to your radius subnet(s)... It matters that your management ip routes to your radius subnet(s).
-Scott
George Stefanick
To add to this ... If you have a WLC in the DMZ and you do say office extends or 802.1X in some flavor you would need to allow access from the radius server to the DMZ WLC managment address.
Cant the "Radius Server Overwrite interface" feature be used here, where in the interface mapped to WLAN will be used to reach the RADIUS server
NikhiL
You can do vlan override... This will change the vlan a user will be placed on depending on what vlan id you specify on the radius server. The wlc has to have a dynamic interface on each of the vlans.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008076317c.shtml
Scott Fella
Sent from my iPhone
-Scott
