What is the spec of WLC 5508 and 4402, CPU and MEM? Thanks.
Admond CW Yeung
I cant found any information about WLC 5508 and 4402s' spec of what type of CPU and size of MEM. Thanks.
4402 is having 512MB memory where as 5508 is having 1GB (based on "show memory statistics" output)
Also during bootup it will show (here is 4402 as example)
System will now restart!
Bootloader 7.0.116.0 (Apr 13 2011 - 14:30:45)
Motorola PowerPC ProcessorID=00000000 Rev. PVR=80200020
        CPU: 833 MHz
        CCB: 333 MHz
        DDR: 166 MHz
        LBC: 41 MHz
L1 D-cache 32KB, L1 I-cache 32KB enabled.
I2C:   ready
DTT:   1 is 33 C
DRAM:  DDR module detected, total size:512MB.
512 MB
8540 in PCI Host Mode.
8540 is the PCI Arbiter.
Memory Test PASS
FLASH:
  Flash Bank 0: portsize = 2, size = 8 MB in 142 Sectors
 8 MB
L2 cache enabled: 256KB
Card Id: 1540
Card Revision Id: 1
Card CPU Id: 1287
Number of MAC Addresses: 32
Number of Slots Supported: 4
Serial Number: FOC1229F08U
Unknown command Id: 0xa5
Unknown command Id: 0xa4
Unknown command Id: 0xa3
Manufacturers ID: 30464
Board Maintenance Level: 00
Number of supported APs: 12
In:    serial
Out:   serial
Err:   serial
Rasika
**** Pls rate all useful responses ****
        CPU: 833 MHz
        CCB: 333 MHz
        DDR: 166 MHz
        LBC: 41 MHz
I2C:   ready
DTT:   1 is 33 C
512 MB
Memory Test PASS
FLASH:
 8 MB
Card Id: 1540
Card Revision Id: 1
Card CPU Id: 1287
In:    serial
Out:   serial
Err:   serial
Rasika
Thanks a lot. You are the man!
