What to upgrade first for smooth Transition
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
05-30-2019 01:06 AM - edited 07-05-2021 10:29 AM
We are trying to upgrade Prime, MSE and WLC to the latest code. But need to figure out what to upgrade first. Is there a procedure to follow? Checked the compatibility chart and Upgrade guides but did not find specific info. Please advice
- Labels:
Mobility Express
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-30-2019 01:27 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-30-2019 01:58 AM
You have to check the release notes of the WLC, Cisco Prime and MSE, Based on that you have to take a decision.
Refer : Cisco Wireless Solutions Software Compatibility Matrix
For an example if you are upgrading your prime with 3.6 Code, your controller code support will be as per the Table 6 Cisco Prime Infrastructure and Cisco Wireless Release Compatibility Matrix based on the model of your WLC.
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
