What will be installed on the client during phase 0 in PAC (Protected Access Credentials)?
ccnaluna93
This is what Cisco book says about PAC phases:
Phase 0: The PAC is generated or provisioned and installed on the client
Phase 1: After they authenticate each other, they will negotiate a TLS tunnel
What will be installed on the client in phase 0? a certificate?  they only refered as "PAC" I have read some other websites but they don't explicitly say if it is a certificate...
I would appreciate your help!
EDIT: After researching more I have found that it is not a certificate but some files, but what kind of files?:
I found this from CWSP-205 book
Rasika Nayanajith
Pls go through below video, that explains EAP-FAST process well
EAP-FAST by Vybhav Ramachanran
Configuring 802.1X with Cisco ISE and EAP-FAST
Rasika
*** Pls rate all useful responses ***
