What will happen when I remove controllers from mobility groups?
jeffrey.miller
Community Member
I'm wondering what exactly will happen when I remove a controller from a mobility group?
1) Will it require a reboot? (I don't think so, nothing I've found says so)
2) Will it deauth/reauth the AP's connected (I don't think so, nothing I've found says so)
3) Will it do anything else goofy?
I have 2 RF groups spanning continents over low speed links. All that is transmitted over mobility groups is session data correct? Not usernames, not ??? What am I missing here? I'm banging my head against the wall because I can't figure out why someone would configure the system in this way.
Setup:
WLC 4404, WLC 2100's
WCS 5.2.148
11xx series AP's
Radius Auth for domain users
a few SSID's, one guest SSID, no DHCP on any of the controllers
Thanks in advance,
0 Replies 0
