When is bridge/mesh mode available in 1850/2800/3800 APs?
Dominik Zeiger
Hi.
I am planning to upgrade our APs from 1140 to something future proof and was looking into the Wave 2 APs. Due to my office environment I depend on bridge mode. In the 1850 data sheet it just states "future", but this document is already from April 2016.
So I am wondering whether there is a plan on when bridge/mesh will be available on those APs?
Best regards
That really leaves you with the x702's or the actual outdoor mesh AP's.  You would have to ask your Cisco Var in regards to if and or when they might introduce those features. The issue is if they will not and only make outdoor AP's only function as mesh.
-Scott
-Scott
Scott Fella
I really doubt that might happen soon. Your better off looking at the 2802's then. There are a lot of bugs with the x802's so keep that in mind. Take a look at the latest code and the resolved and open caveats.
-Scott
-Scott
Thanks for the quick response.
While doing a search I came across the release notes for 8.3. There is a section "Features not supported on 1850, 2800, 3800 Series APs", which includes "Mesh" and "Bridge".
So actually none of the newer APs supports it and (likely) wont in the near future? The next closest APs with this feature would be the x702 series?
-Scott
-Scott
