I'm wondering about the documented approximate range of these two Cisco antennas, that differ a lot.
Can someone explain the big difference in range between these two antennas that have both the same antenna gain of 5.2 dBi and beam width 360°H and 38° V
AIR-ANT1728 Indoor antenna
Indoor range at 54 Mbps: 114ft, 35meters
AIR-ANT2506 Outdoor antenna
Range at 54 Mbps: 0.21miles, 340meters
Can we use the 2506 also for Indoor applications ?
Please advise and explain.
Thank You in advance.
Winfried
