Wierd WGB problem.
Martin Erman
Community Member
Hello.
I'm having this wierd problem with an IP phone behind a WGB. The setup is like this:
Cisco controller -> Switch -> switch -> AP (Air LAP1142) -> WGB (Air LAP 1262) -> switch -> IP phone.
The phone works, sometimes. Sometime for days, sometime for hours, then it disconnects and what I have to do then to get it working again is to run this command on the bridge. "no workgroup-bridge unified-vlan-client", then wait for it to disassociate, then run "workgroup-bridge unified-vlan-client" and after that it gets a stable connection (for a undetermined amount of time).
I think I have tried everything by now and I would be extremly grateful for any help regarding this issue.
Here´s the WGB config:
version 15.2
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
enable secret 5 ***************************
no aaa new-model
no ip routing
dot11 syslog
dot11 ssid *******
   vlan 664
   authentication open
   authentication key-management wpa version 2
   infrastructure-ssid
   wpa-psk ascii 7 ********************************
username Cisco password 7 **********
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
encryption vlan 664 mode ciphers aes-ccm
ssid *******
antenna gain 0
station-role workgroup-bridge
infrastructure-client
interface Dot11Radio0.664
description **********
encapsulation dot1Q 664 native
no ip route-cache
bridge-group 1
interface Dot11Radio0.668
description *************
encapsulation dot1Q 668
no ip route-cache
bridge-group 68
bridge-group 68 spanning-disabled
interface Dot11Radio0.715
encapsulation dot1Q 715
no ip route-cache
bridge-group 15
bridge-group 15 spanning-disabled
interface Dot11Radio0.717
encapsulation dot1Q 717
no ip route-cache
bridge-group 17
bridge-group 17 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
interface GigabitEthernet0.664
no ip route-cache
bridge-group 1
interface GigabitEthernet0.668
no ip route-cache
bridge-group 68
interface GigabitEthernet0.715
no ip route-cache
bridge-group 15
interface GigabitEthernet0.717
no ip route-cache
bridge-group 17
interface BVI1
ip address **.**.**.** 255.255.248.0
no ip route-cache
ip default-gateway **.**.**.*
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
logging synchronous
line vty 0 4
session-timeout 3600
exec-timeout 180 0
login local
transport input all
end
5 Replies 5
George Stefanick
Are there other devices on the switch that are disconnecting as well ? Do you have wcs ? Does it show the bridge disconnecting ?
There are other devices connecting to the switch, but in the native vlan, and they are not disconnecting. The bridge is not disconnecting from the AP either. It does not matter if its an IP phone, or a computer either. And yes, we have wcs, but it´s wierd because the devices on the native works perfectly.
//M
Martin Erman
Community Member
"clear bridge" also makes the phone reconnect.
Anyone with any information about this, please?
/M
Martin Erman
Community Member
Sorry for bumping this, but is there anyone with any idea´s.. I really need to get this working properly..
/M
Martin Erman
Community Member
Still noone with any ideas?
