Wifi 6 Features
Learnercisco
Level 5
Level 5
Hi Tech people,
In my Setup i want to know if  WIFI 6 Connectivity is available ton Cisco WLC 5500 ?  if we use 3800 AP with WLC 5500, how can we achieve the WIFI 6 Feature.  what will be the case if Wireless Controller Supports wifi 6 and AP doesnt not.
Cisco is recommending to use 9100 AP for Wifi 6, so is there any Specification hardware requirement for WIFI 6 or simlpy enable this by upgrading Firmware on Controller and AP (in my case WLC5520, AP-3800)
thanks in advance.
Leo Laohoo
APs that support 802.11ax (aka WiFi 6) are the Catalyst 9k AP (not to be confused with Catalyst 9k switches).  The Catalyst 9k AP are supported on 8.10.X.X.
In order to enable WiFi 6, the number of usable channels go down.  Remember the difficulty of widespread use of 2.4 Ghz in a dense environment because of lack the lack of usable non-overlapping channels?  Same thing with 802.11ax.
Scott Fella
WiFi 6 is only supported on access point hardware starting with the 9100’s. Not other access point Cisco gas is WiFi 6 capable.
-Scott
Hi Scote Fetta,
Thanks for your reply,
Simply Cisco WLC 5500 Supports WIFI 6 and for Access point we need to replace AP from 3800 to 9100 for fully WIFI 6 deployment
Only the 3504, 5520 and 8540 support v8.9 and v8.10 that is required for the newer access points. Take a look at this guide:
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/feature-matrix/ap-feature-matrix.html#_Toc42781653
-Scott
