WIFI ACCESS ISSUES
Mercy-Sapalo
Community Member
Subject: Intermittent SSID Connectivity Issues – Cisco C9130AXI-E APs
We are currently experiencing an issue where some users are unable to connect to the SSID, while others who are already connected are being intermittently disconnected.
The environment is running Cisco C9130AXI-E Access Points with the Cisco Embedded Wireless Controller on Catalyst Access Points, software version 17.12.7a.
Could this issue be related to the access point software version? Has version 17.12.7a been associated with any known wireless connectivity, authentication, roaming, or client disconnection issues that could explain this behavior?
Any guidance or recommendations would be appreciated.
Mark Elsen
  - @Mercy-Sapalo                     (Added) : Validate the overall configuration of the EWC based 9800 controller
        using the CLI command show tech wireless and feed the output
        from that into WCAE
                                             - Upgrade the latest advisory software version :
                                                    https://software.cisco.com/download/home/286323998/type/286323077/release/17.15.6
                                             - Consider  abandoning the EWC based solution because it it EOL:
                                                You can deploy the 9800-CL virtual controller with up to 50 access points
                                                for free!
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Mark Elsen
   - @Mercy-Sapalo                  Get overall insights on client behavior and health with commands from :
                                                https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/217738-monitor-catalyst-9800-kpis-key-performa.html#toc-hId-866973845
                                                Debug clients unable to connect with instructions from :
                                                https://logadvisor.cisco.com/logadvisor/wireless/9800/9800ClientConnectivity
                                                These logs , so called RadioActive traces can be processed with :
                                                Debug Analyzer
 M.
Mark Elsen
        from that into WCAE
                                                for free!
 M.
Leo Laohoo
Reboot the affected APs.
