WIFI Asking for Username and Password
john000023
After a building power outage our wireless network is asking for a username and password to connect to the wifi, does anyone know how to disable the username and only have it ask for the password?
Our wireless is a Cisco 2106 with 4 access points.
Thanks in advance.
kcnajaf
Level 7
Level 7
Hi John,
What sort of authentication are you using for the problem ssid? Please verify if the authentication methods was charged after reboot?
Najaf
George Stefanick
Can you post the show run-config on the controller ..
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
kcnajaf
Level 7
Level 7
Hi John,
Najaf
The issue has been solved. Thank you for your repsonses.  We found that the security policy had been changed from the power outage.  Setting it back to PSK fixed the issue.
Thanks!
Thanks for using the rating system...
Good to hear things are working as expected.
Najaf
