WiFi channel 13
fb_webuser
Level 6
Level 6
Is there any way of connecting to a WiFi running at channel 13 ? I mean is there any possibility of adjusting my wifi adapter tuned to channel 13?
Posted by WebUser Vikas Mishra from Cisco Support Community App
Stephen Rodriguez
Channel 1- 14 are avaialble in Japan only, so far as I remember.  So you would need an adapter for Japan.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
You could look for a driver or perhaps a japan nic .. Why do you have an ap that allows channel 13 ?
Abhishek Abhishek
As per your query i can suggest  you the following solution -
Channel 13 is only available in Japan.
Hope this will help you.
