Wifi channel issue
Sherif Hassan
Dears,
I am experiencing a significant issue with the Cisco Access Point model 'AIR-AP3802I-B-K9,' where certain devices are unexpectedly disconnecting. When attempting to reconnect, the error message 'Cannot connect to this network' appears on Windows. Upon investigating the root cause, I suspect the issue may be related to the wireless channel configuration. I attempted to resolve it by switching the channel to 1, 6, and 11, but the problem persists.
Edit 23/08/2025 09:53 AM
Second Issue, it takes time to join the network, maybe 45 seconds.
I have 5 Access Points, and I'm controlling them by making one Access Point a Controller
Cisco Aironet 3800 Series Mobility Express
Software Version: 8.5.161.0
Radio Policy: All (5GHz - 2.4 GHz)
Security Type: WPA2 Personal
Kindly let me know how I can solve this issue.
Below is the Access Point Configuration.
18 Replies 18
show wireless exclusion-list <<- I think this client add to exclusion list
MHM
Hello MHM,
No, I didn't add him to the exclusion list because there is no exclusion list I have created.
It automatically add if client failed to authc multi times
MHM
From where can I find this list
eglinsky2012
What software version is the AP/WLC running? What type of authentication is on the SSID, is it 802.1x or WPA2-PSK, etc?
If you haven't already, try going to the list of known networks, "forget" the SSID, then reconnect. Also try updating drivers for the WiFi device, and go through the computer or NIC manufacturer for the latest drivers rather than Windows Update.
Hello @eglinsky2012
I tried to do that by forgetting the Network, then re-joining but the problem still exists, and this issue affects most of the employees, not just one user.
Below are the Access Points Configuration:
Security Type: WPA2 Personal General Settings.pngWLAN Security.pngVLAN & Firewall.pngTraffic Shaping.pngAdvanced.png802.11u Settings.png
 - @Sherif Hassan        What is the WLC  model ?
  M.
eglinsky2012
Saikat Nandy
Interesting..!! Few pointers -
1. What made you think that the issue could be related to the channels?
2. Secondly, why you had to switch the channels to 1,6 & 11? What were the channels before?
3. What's the WLC model and version running?
4. Have you taken any debug client (AireOS) or RA trace (9800) reproducing the issue?
Hello @Saikat Nandy
1- Because I searched for some reasons for this issue, and I got that maybe the interference between the channels causes that.
2- Before it was automatic, but I got the same issue and I searched and I found that the best channels for 2.4GHz are 1,6,11.
3-Cisco Aironet 3800 Series Mobility Express and Software Version: 8.5.161.0.
4-No, if know know how to do that, please let me know
thanks for the response.
Even when it was automatic, it should have been using channels 1, 6 & 11 as these are the only 3 non-overlapping channels available in 2.4Ghz.
there are multiple reasons for the disconnections. 2 things I would suggest -
1. share the output of 'show run-config' for a review (before running the command you should run 'config paging disable')
2. capture debug reproducing the issue. Command is 'debug client <mac addr>'. It will print the output in the terminal session. Wait for the issue to repro and then stop the debugging by 'debug disable-all'.
that image shows clients connected to the WIFI, but cant access the internet
Does the client have an IP address? Can it access the default gateway via ping
Can it resolve DNS entries via nslookup
is it all clients, and all APs?
Is it always affecting these clients or intermittent
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Hello @Haydn Andrews
No, it doesn't connect because there are two issues here:-
1- The first one takes a long time to join, maybe 45-50 seconds
2- After taking a long time, it cannot connect as you see, and there is an error message appearing "Cannot connect to this network.".
- Yes, the client has a static IP address, and I have disabled the DHCP.
- No, it cannot because at this time it isn't connected to the network yet.
- Yes, this issue with all Clients and AP.
- Yes, it is always affecting the clients
Here is the configuration
RF OPTIMIZATION.pngGeneral Settings.pngWLAN Security.pngVLAN & Firewall.pngTraffic Shaping.pngAdvanced.png802.11u Settings.png
JPavonM
First of all, @Haydn Andrews that screenshot shows Windows unable to connect, the other way will be Connected but no Internet connection:
Few points here:
  1. Check your Windows laptops have the latest drivers installed for the wireless adapter. Check the support page of the vendor fisrt, and then also check the support page of the manufacturer (in the case of Intel adapters).
  2. Why are you using 2.4 GHz band? You can normally find connectivity issues if the band is congested or occupied by interfering devices, thus leading some clients to not connect, or disconnect.
  3. Check you WLC/AP code has no bugs that may point to the issues you are suffering.
  4. I've suffered weird issues with AP3802 not receiving enough PoE budget thaus making them to randomly disable radios or dropping clients. Check the PoE budget of the AP.
  5. Check if your are reaching the maximum re-association failures, thus leading the WLC to blacklist your MAC address for 180 seconds. Re-association failures may happen if the client send multiple EAPOL messages but they don't reach the RADIUS server, or if the client does not receive the responses and restart the asscoiation in a loop. (Check your RADIUS logs)
  6. Check if you have configured the maximum number of clients per AP/WLAN and you are hitting that figure.
  7. Check the RSSI/SNR is proper or if the clients are close to the border of the coverage cell.
  8. Check your basic/mandatory data rates, this may be setup to a higher value and the clients may be not able to get those rates becuase they are far from any AP.
  9. Finally, check if you may be impacted by a DDoS attack. I have found that untrained admins using Meraki APs use to enable wIPS thus making their APs to send dis-association packets to other neighbour networks if they configured the wIPS feature wrongly.
