WiFi - Logging?
Armymanryno
Level 3
Level 3
How can I turn off logging on this AP? Every time I try and configure it, I get flooded with a new line of information. I was thinking #no term mon but that doesn't work. Is there a way?
Mark Elsen
 - In the end you could try re-setting the ap , and restore it's configuration (if all else fails).
   M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Rasika Nayanajith
You can disabled it (temporarily) like below
#debug capwap console cli
#no logging console
Since it is WLC managed AP, you can't save local configuration changes on AP itself. Therefore once AP reloads it will go back to original configs pushing through WLC
Rasika
*** Pls rate all useful responses ***
