Wifi Monitor tool
saroj pradhan
Hi   ,
  i have  cisco  AIR1142  WiFi  in  my  network. i want  to  monitor  the  connected  users  and  triffic  through a  Monitor  Tool.
please  suggest  any  one  avaialable.
Saroj Pradhan
Sandeep Choudhary
HI Saroj,
You can use Cisco tools like Prime INfra(Its depend on ur budget).
or
There is one tools that you can start with The Dude from Mikrotik. This tool is made to monitor Wireless netwroks via probes, SNMP, etc. You can draw maps per location and track BW usage on each AP interface. Thsi tool helpes a lot and it is quite easy to set it up. It works better on XP or 2003.
Beside this tool, there are several tools described in how-to from Muhammad Bilal
http://community.spiceworks.com/how_to/show/2532
http://www.mikrotik.com/thedude.php
If your aps support snmp, this will allow you to view traffic volumes on the wlan etc
check fluke network equipment also they are very good
abwahid
Level 4
Level 4
check these free tools
-securityxploded
-InSSIDER.
If you have budget then go for Cisco Prime NAM appliance
