Wildcard Certificate and Wireless Lan Controller
salilai01
I'm working with wlc 5508 version 7.2.111.3 and I'm looking to use a wildcard certificate, I've just checked on the forum that there was a bug-id and it seems it's been closed with a workaround of not using wildcard certs, is it resolved now?
If yes, could you indicate to me how can I proceed to install it quickly?
Amjad Abdullah
The bug was about bad behavior when the wildcard certificate is used. The status of the bug now is "Terminated". That means it was found that the root cause for this bug is not really a bug (bad description, normal behavior...etc).
So, I think you can go with the wildcard certificat you have. The bug was opened on 5.2 version which is very old comparing to 7.2.
Let us know how it goes.
Amjad
Rating useful replies is more useful than saying "Thank you"
Scott Fella
Just to add.... If your using it for WebAuth it should work fine. Just make sure you bundle the chained certificates properly and define the FQDN on the VIP.
-Scott
