Will changing username credentials for AP in WLC cause AP disassociate
subodh goyal
I want to change username credentials for all the APs associated with WLC in Wireless>> Global Configuration>>
Can anyone confirm if we do any changes in WLC Global configuration, will that affect any AP association?
Hi @subodh goyal
 If you are going to change only the AP credentials no, the AP will not disassociate from the WLC.
But, you be sure that any change on the WLC that may cause client interruption, the WLC will warn you.
