Windows Transmit Power setting
When using a WiFi chip like Intel 7265 AC there is a Advanced Property in Windows to set the Transmit Power. It is scaled from 1 Lowest to 5 Highest. Does any of you know what milliWatt they correspond to?
I can't seem to find anything about this on Google.
Philip
mohanak
Hope you will get answer from intel community group : https://communities.intel.com/community/tech
Rasika Nayanajith
Though it is not explicitly stated below document will contain useful info about this chip
https://fccid.io/document.php?id=2245709
Here is the power output depend on the frequency it operate
Rasika
*** Pls rate all useful responses ***
