WINS over wireless
mfahy
Community Member
I have two networks connected via an Access Point and a WGBridge. I can ping from both sides to any PC or server I care to. I can not transfer WINS information, I have placed LMHost files on both sides and still can not browse. HELP!
rokibbe
Level 4
Level 4
If the two WINS servers are pointed at each other and set as replication partners of each other, and you said you can ping from anywhere to anywhere, it sounds like you may have a bigger Microsoft issue, and might get the best help from a local MCSE or Microsoft support provider.
