Wired guest access using Cisco 3850 based WLC
hardik3946
Hi Guys,
We are building up a guest tunnelling mechanism with 3850 switch ( integrated WLC). My question is , if it is possible to tunnel the directly connected wired clients too via EOIP tunnel initiated from 3850 switch to Guest anchor along with wireless AP clients on same switch. ?  This has come up as we have 3850 switch where we expect both types of guests ( wired and wireless) .
Can anybody please explain?
Dave
Rasika Nayanajith
Hi Dave,
Tunneling of wired Guest Access is not supported in 3850 (as of IOS-XE 3.6). It may  come in future releases, but never know.
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ibns/configuration/xe-3se/3850/ibns-xe-3se-3850-book/ibns-wired-guest-access.html
  • Tunneling of wired clients is not supported when the client is attached to a port at the Cisco Next Generation Wiring Closet (NGWC) device that is configured for open mode.
  •  Tunneling of wired clients is not supported after successful web authentication at the NGWC device because automated IP address reassignment is not supported after web-authentication.
  • The NGWC device supports network access only via the tunnel based on the web authentication that occurs at the controller.
  •  The Network Advertisement and Selection Protocol (NASP) is not supported for wired clients.
  •  High availability is not supported for wireless sessions. If the wireless controller fails while providing tunneled guest access for a wired client, the state is not automatically recovered.
  •  Inactivity aging is not enforced for a wired client that is provisioned to the wireless controller; for example, within a RADIUS Access-Accept request that is received after web authentication is performed at the controller.
Rasika
**** Pls rate all useful responses ****
