Wired guest network
Adam Watts
Level 2
Level 2
A quick question,
Do i need a anchor controller in order to make a guest network work?
I need to be able to authenticate users on a wired network before they are allowed assess onto our network.
i've set up a similar system on our Internet guest network and it works well. that uses a remote anchor controller on our dmz. For this scenario we don't need a remote anchor as we want to put it onto a vlan on our main network.
Any ideas we would be using the on site 5508 controllers hopfully to implement this solution.
Many thanks,
Adam
Stephen Rodriguez
No an anchor controller is not 'required' to do either Wireless or Wired guest access via the WLC.
Having the anchor is 'best practice' as you are forcing these untrusted devices outside of your LAN.
5508 should work for this like a champ.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Stephen Rodriguez
Steve
HTH,
Steve
Thanks for that Steve,
I'll have a play and see what i can do.
Adam
Hi Steve,
set it up yesterday and was one of the easiest setups i've done in a while. works a treat.
Adam
