Wireless 1410 Throughput Test and Security Configuration
unnikannanvj
Hi Team
Could you please address on the security configuration of the 1410 bridge and on how to test the bandwidth/throughput between two 1410 Bridges setup for point-to-point connectivity.
We have setup this in one of our Client sites.
Awaiting your reply.
Thanks in advance!
Unni Kannan
Systems Engineer
2 Accepted Solutions
Surendra BG
here is the config example.
https://supportforums.cisco.com/docs/DOC-15193
Regarding the throughput please use the software called IPERF and regarding the BW use the command "show dot11 associations all"
Please dont forget to rate the usefull posts!!
Surendra
Surendra BG
Its present in the link..
U can go for WPA PSK..
dot11 ssid test
   vlan X
   authentication open
   authentication key-management wpa
   wpa-psk ascii 7 cisco123
and encryption as TKIP
encryption vlan X mode ciphers tkip
Lemme know if this answered ur question!!
Surendra
Surendra BG
Surendra BG
Surendra
Surendra BG
Hi Surendra
Thanks a million for your valuable inputs.
Could you also please help me on how to address the security configurations in Cisco 1410 series ?
Thanks in advance.
Unni Kannan
Systems Engineer
dot11 ssid test
   vlan X
   authentication open
Surendra
Surendra BG
