Wireless 3800E APs with External Antenna need to connect with Extended Cable
Mohammad-
Hi Team, Please help!
I need to connect AP3800E external antenna AP with extended cable of 2 meters.
can i use below part for above:
AIR-AP3802E-E-K9--AIR-ANT2535SDW-R
with cable  AIR-CAB005LL-R-N=  (5-ft low-loss cable, one RP-TNC plug, one 90-degree N male connector)
7 Replies 7
Mohammad-
Any help to for Indoor access point with external Antenna need to connect with extendable cables?
Mohammad-
Any help to for Indoor access point with external Antenna need to connect with extendable cables??
@Scott Fella Thanks Mate for your response!
1 option --I  am planning to use AIR-AP3802E-E-K9 with AIR-ANT2535SDW-R (which cable should i use for antenna extension) are Antenna extension with cable possible?
2 -- I am planning to use AIR-AP1562E-E-K9 with AIR-ANT2547VG-N (with cable) AIR-CAB002L240-N=
3--Is there any other options available?
Planning to use with 3504 WLC
It doesn’t matter what controller, you just need to use the appropriate antenna for the model ap you have.
-Scott
Again, when you want to use an external antenna that is not attached to the ap itself, you need to find a single antenna that has the appropriate number of cable leads. You don’t want to extend dipole antennas as that will cause you issues.
-Scott
