Wireless 5508 controller - Guest Wlan time of day restrictions ?
dclee
Looking to add time of day restrictions to our Guest WLAN that is currently in its pilot phase.
Is there a way to config time of day access to a WLAN ?
Cheers
Dave
George Stefanick
Dave,
There is nothing in the controller that allows you to do this... However you can achive this in a few manners..
1) Time ACL on the vlan. But your guest ssid will still be shown.
2) If you have WCS you can schedule a WLAN enable/disable with a template. This is what some of my customers use. They will create a template that triggers at 6pm to disable the wlan and at 7am enable the wlan.
I hope this helps.
7 Replies 7
Stephen Rodriguez
On the WLC directly, there is not currentlya method to do so.  IF you are authenticating your guest users via AD/ACS/ISE, then you can set a day/night restriction on the user account there.
HTH,
Steve
Please remember to rate helpful posts or to mark the quesiton as answered so that it can be found later.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
George Stefanick
Dave,
I hope this helps.
Thanks George, I installed WCS and configured the template. Seems to work just fine.
  Much appreciated.
Dave
No worries... There is always a way around everything. If you wouldn't mind, can you mark this as answered ?
How is this Template created?  Can it be created on a recurring schedule? I can't seem to find the solution
Thanks!
-Craig
Hi Craig,
Welcome to CSC.
You can find this in the WCS guide under manage wlan status schedules
http://www.cisco.com/en/US/docs/wireless/wcs/7.0MR1/configuration/guide/ctrlcfg.html#wp1081605
I hope this helps
Thanks George.  I've figured it out!
