Showing results forĀ
Search instead forĀ
Did you mean:Ā
Wireless 7925G Phones and EAP-FAST and AES
greg.murray
I was reading  through the Admin Guide for Cisco Unified Communications Manager 7.0(1) for the Cisco 7925G Wireless Phone and discovered that if you select the Authentication Type on the Phone as EAP-FAST then it supports WEP and TKIP. I was wondering if it does not support this mode with AES and if so has anyone run this deployment?
I ask this because I have deployed this and notice that we get numerous Authentication Failures and Errors on the phones and they lock up periodically with a message;
Authentication Failed!
Your user credentials may be incorrect
Profile: Profile 1
When I enter the new original password for the account it still does not authenticate.
As a test I have also run a new SSID with EAP-FAST and TKIP and I get no such problems
Greg
2 Accepted Solutions
dancampb
Level 7
Level 7
Yes, they support AES.  Try configuring the phone for AKM.  Keep in mind that CCKM with AES is not supported until 1.3.4.
Leo Laohoo
Using 1.3.4 with WLC firmware 6.0.196.0.  I've enabled WPA2 with AES and works pretty good!
dancampb
Level 7
Level 7
Leo Laohoo
I have upgraded the phones to 1.3(4) and this resloves the error message I received on the phones. I was aware of that CCKM was not supported with AES but following the upgrade all is good.
