Wireless AAA
zohaib.shabir
Frequent Visitor
Frequent Visitor
IN UWN solution, i have 5508 controllers and one ACS appliance which is integrated with Active directory for user authentication.if the ACS goes down how user authenticate or what work around we can do.
George Stefanick
They wont. If you have your WLAN pointing at a ACS and should that ACS go down with no back up ACS, you are out of luck my friend...
George Stefanick
