Wireless Access Point
Eng.Massawe
Community Member
Hallo! i was asking that, Does Cisco still supporting Ap Aeronet 1130Series ??
Because when i do save changes through web it does not Save any Changes; but when i use CLI using putty it works.
Any Assistance please.
Rasika Nayanajith
Yes 1130 still supported.
In autonomous AP I would not bother GUI, if CLI works go with that
Rasika
*** Pls rate all useful responses ***
thanks Mr Rasika....
The thing is that i don't know how to use CLI well to set SSID, Security and Authentication. There are Read Only and Read and Write Does that affect user?? Because there something like when you are using CLI you are Super User but GUI it seem like not a super user.
#BVI 1 192.168.100.5 255.255.255.0
#no shut
#username mmm privilege 15 secret xxxx
#lin con 0
#login local
#lin vty 0 4
#password xxxx
Note: On the web i tried using 192.168.100.5 and Prompted to enter Username and Password that are  mmm and secret xxxx.
When i enter this address on the GUI i can get Web Interface. and when i change any thing and Press Apply nothing Responds and no changes. I tried a little harder, please.....
Initially it would be hard to understand CLI, but one you get familiar it is the best way to configure an autonomous AP.
Below posts should give you some hlep understanding those CLI configs
http://mrncciew.com/2013/03/02/autonomous-ap-with-wpa-psk-security/
http://mrncciew.com/2013/03/03/autonomous-ap-as-local-radius-server/
http://mrncciew.com/2013/11/14/autonomous-ap-with-external-radius/
If you still want to try GUI, then try to upgrade the AP image & see if that makes any difference ?
Rasika
mohanak
Yes it is supported.
Table 1. End-of-Life Milestones and Dates for the Cisco Aironet 1130 Series
Milestone
Definition
Date
End-of-Life Announcement Date
The date the document that announces the end-of-sale and end-of-life of a product is distributed to the general public.
January 25, 2013
End-of-Sale Date
The last date to order the product through Cisco point-of-sale mechanisms. The product is no longer for sale after this date.
July 26, 2013
Last Ship Date:
HW
The last-possible ship date that can be requested of Cisco and/or its contract manufacturers. Actual ship date is dependent on lead time.
October 24, 2013
End of SW Maintenance Releases Date:
HW
The last date that Cisco Engineering may release any final software maintenance releases or bug fixes. After this date, Cisco Engineering will no longer develop, repair, maintain, or test the product software.
July 26, 2014
End of Routine Failure Analysis Date:
HW
The last-possible date a routine failure analysis may be performed to determine the cause of hardware product failure or defect.
July 26, 2014
End of New Service Attachment Date:
HW
For equipment and software that is not covered by a service-and-support contract, this is the last date to order a new service-and-support contract or add the equipment and/or software to an existing service-and-support contract.
July 26, 2014
End of Service Contract Renewal Date:
HW
The last date to extend or renew a service contract for the product.
October 21, 2017
Last Date of Support:
HW
The last date to receive applicable service and support for the product as entitled by active service contracts or by warranty terms and conditions. After this date, all support services for the product are unavailable, and the product becomes obsolete.
July 31, 2018
