Wireless adapter
sannedhi
Community Member
I am using a 802.11a card on my laptop and it is running XP OS. For some reason after restarting and logging into the machine I have to reinsert the card to get the signal. My machine is set to start the "Network Connections" service automatically.
Then why does I need this manual reinsertion of the card to make it working.
TIA
derwin
Level 10
Level 10
What NDIS ACU and firmware versions ?
Are you using any kind of EAP authentication ?
What power mode CAM, Max PSP or Fast PSP ???
